1995 Subaru Legacy with check engine light on
Hello, There is a check engine light on that seems to go out on occasion. The only problem the vehicle seems to have is that on occasion it will almost lock up when downshifting into first. Like if the emergency brake suddenly goes on. It won't lock up but I need to use more acceleration to get it to move. Then once the speed is up it is fine again. This won't occur all of the time only when the vehicle is hotter. It does not overheat but it does not occur when vehicle is cold. Thanks
Read the faults that are recorded and make sure the clutch is not burned.
  • Older Subaru check connector.pdf
forester smell issue
