1993 Subaru Legacy Radio Removal Help Needed
P
ptrainour
Can someone tell me how to remove the radio from a 1993 Subaru Legacy?
Does one have to remove the floor shifter console to get to the radio?
Are there any clips that one needs to be careful of when removing as to
not break them?
Can I remove the radio with standard tools or do I need special tools
to get at the screws and bolts?
not break them?
I recently replaced the radio in my 2000 Legacy. The procedure might be
the same. I had to start by popping out the trip around the gear
shifter. Then I worked my way towards the dashboard, prying and
unscrewing. Pry gently, and you'll be fine. No special tools needed.
The hard part is reaching in deep. I lost two screws deep in the dash.
I'll never get the back, but I'll be OK without them.
Funny i just did mine 98, and lost two screw as well... use magnet tools.
Nothing special either except i had hard time with the cigaret lighter
reinstallal.... I have install Eclipse cd5405... Good but the volume know is
not deep enough to be use with the tip of the finger proprelly.....NOT
RECOMMENDED....
mtbe
