Where is the 2010 series Outback AC condenser drain tube located?
Hi, I have a 2010 Outback Limited that has a lot of water ine the front passenger side floor. I can see water dripping from a wire harness up under the glove box compatment, nea the fire wall. The sun roof is not the issue. Is ti from the AC condensation unit drain tube being blocked and overflowing into the car? Is there are drain port under the car that can be cleared? Anyone else ever had to deal with this problem an ony year Outback or other model? THANKS!
It could be ingress from the roof (you said no) a seal or the a/c drain. Not a lot of other choices. Drains should be leaned annually. It is a well known issue on...cars.
It ended ups that the drain tube runs down along the side of the inside middle housing (transmission) and goes out a port grommeted hole in the floor. When I disconnected it from the interior connectiona lot of water poured int the cabin - passenger side. Clearly, the drain tube was clogged. Got it cleared and I hope that fixes the issue of water in the cabin - lots of water - I vacuumed up almost 2 gallons yesterday - following several days of heavy rains here in the NW
Thank you Bmart!.
Nice work! Sunroof and a/c drainage are not great. Room for improvement!
martjeet
