Warmed up or not?!
F
Fred Boer
Good morning:
An odd thing this morning: it was a very cold night (-20C), and when I
started my Subie this morning, the temperature gauge indicated the engine
was warm more quickly than I would have normally expected. I got out of the
car momentarily, leaving the car running, and when I got back in, the temp
gauge had dropped back down indicating the engine was still cold. It then
took about the time I would expect to indicate a warm engine.
Is there something wrong?
Fred said:
Good morning:
Hmmm - is it possible there was a blockage of 'ice' or the coolant was
in a sludge/gel condition?
Carl 1 Lucky Texan said:
Hmmm - is it possible there was a blockage of 'ice' or the coolant was in
Hi Carl:
Thanks for responding! I suppose it might have been blocked somehow, but if
so, it wasn't because of the condition of the coolant. I just had the heads
done, and the coolant is new... It does seem reasonable though that perhaps
somehow a small amount of coolant was hot, but then the bulk of the coolant
started flowing.
Anyway, the car has run fine today, so perhaps it was nothing.
Thanks!
Fred
Hi Carl:
started flowing.
Thanks!
Fred- Hide quoted text -
- Show quoted text -
Well, the 'mix' could be off. Fo rinstance, in a 12 quart system, 7 of
water and 5 of glycol only protects to about -15 degrees.
Hi Fred!
I'd bet the gauge needle was just stuck as a result of the extreme
cold. It'll happen to the speedo sometimes as well; it will go up to
30-35MPH and then stick there.
I don't know if this is caused by moisture getting into the instrument
panel and then freezing, or if it's just whatever lubricant Subaru
uses becoming sticky.
In any event, I wouldn't worry about it unless it becomes a regular
thing. even on warmer days.
My guess would be, because it was so cold battery was weak causing
erratic display on the gauge. For max protection, mix ratio is 50-50.
It's not only for winter, summer as well.(anti-freeze, anti-boil)
That's an idea. I know the battery is so-so right now, and it is on my list
for replacement. As soon as I get 4 straight weeks without being in the
shop, I will be putting in a new battery! :)
list for replacement. As soon as I get 4 straight weeks without being in
the shop, I will be putting in a new battery! :)
Can you wait that long?
Just kidding. I think I have a weak one too, but my symptoms are far less
pronounced.
-John O
