racin_ran said:
Does anyone know how or what to
clean the headlights with so we can actually see to drive at night?
Do you have the older style glass or the newer plastic lenses?
If glass, although it's rare, the inside--both lens and reflector--can
become "hazed" because of an imperfect seal between the lamp housing and
the bulb. (If you've ever replaced a headlamp unit w/ one from a junk
yard, they often pull the bulbs and those I've gotten have been pretty
gunky from sitting around) It's an involved process, but you can take
the lamp housing out of the car, remove the bulb, pour a quarter cup or
so of window cleaner in there, swish it all about and let sit for a
while, then rinse and let dry. It may take a couple of DAYS to dry
depending on weather and how macho your hair dryer is! Then put it all
back together, w/ attention to the cleanliness of the connections. A bit
of dielectric grease on the connections helps reduce corrosion and
voltage loss.
If plastic, Meguiar's makes a product called PlastX (sp?) that's just
for that oxidized haze that builds up on the outside of the lenses.
Although I've done it in the past, I hesitate to recommend power tools,
even a Dremel, unless you can be super careful--it's easy to overdo it
and damage the surface of the lens. The PlastX product works well w/
simple "wax on, wax off" hand application, though it may take a couple
of sessions to get all the way thru the oxidation. And, once a lens has
oxidized like that, it's an uphill battle keeping it from doing so
again, so redoing the PlastX treatment every couple of months may be
required. Again, a check of the integrity of the electrical connections
is advisable.
You may also benefit from going to a "brighter" bulb such as the
Sylvania Xtra-vision (other mfrs have something similar.) The "blue"
bulbs popular with the "kewl krowd" don't add anything special in the
visibility department in my experience, and while bulbs like the
"Silverstar" are QUITE bright, reports here have indicated you'll
probably trade brightness for drastically shortened life expectancy, and
they're pretty pricey as well.
Rick C
