Scored flywheel??
David
So my early '03 Forester, 19k miles, is at the dealer to get the none-too-smooth
clutch replaced under the clutch-judder TSB.
They call me and tell me the flywheel is scored, so they're replacing it too,
and it should arrive tomorrow.
I know flywheel changes were part of the TSB, but I'm not sure if they
involved resurfacing or replacing.
Anyway I wonder if it got scored during resurfacing, or if if could have
happened during its 1 1/2 years of service. If so, how?
Edward Hayes said:
If the clutch disk is worn down to the rivets then the rivets will do it.
Makes sense. Thanks.
I guess I can't imagine it's worn down so quickly. They don't usually wear out
on me at all. I didn't own this vehicle for the first nearly 6k miles (so don't know how it
wsa driven then), and due to the tendancy to shudder, I have to slip it on start up more
than I should, but still, 19k miles!
Turns out it wasn't scored, that's just the word the service advisor used on the phone.
The work order said "hot spots", and the tech shoed it to me: discoloration, and surface
cracks. Dunno if that's normal for the flywheels covered by the clutch-judder TSB, or if
it's due to overheating.
Similar Threads
Netsrin94
