RS2.5 that 'Smokes on Start-Up'
Dano58
May look at an otherwise very clean '99 Impreza RS2.5. I understand
all of the issues with the head gaskets. The ad states that the car
smokes upon start-up but then stops, and that it may need valve seals.
Is this a reasonable cause for smoking? No indication of the color of
the smoke.
Thx,
Dan D
(formerly) '99 Legacy L 30th (son's)
Central NJ USA
the smoke.
Thx,
Dan D
Central NJ USA
Valve seals/Valve Guides....
NOT a good indication, usually indicates a VERY tired top end.
You could be burning oil a lot more, but the Catalytic Converter
burns it off (might be hard to pass smog).it smokes because the
converter is not up to temp.
May look at an otherwise very clean '99 Impreza RS2.5. I understand all of
the issues with the head gaskets. The ad states that the car smokes upon
start-up but then stops, and that it may need valve seals. Is this a
reasonable cause for smoking? No indication of the color of the smoke.
Thx,
Dan D
Central NJ USA
I have an '89 Supra, an '89 Mazda 626, and an '85 Corolla GTS that all do
the same thing.
Prbably needs valve guide seals. Or, do what I did...
Get some Castrol GTX for High Mileage Engines. After one oil change the
tell-tale 'start-up puff' went away. If I let the Supra or the Corolla sit
for more than one day the amount of blue smoke went up exponentially. The
Corolla is now off the raod, but I can let the Supra sit for DAYS and
there's no puff when I start the engine (actually, after three days of
sitting, the Supra would smoke for about 3-5 minutes! Now, nothing!)
trykflyr
