I drive a 2013 honda civic. Keep it simple. My wife has the 2020 outback. Our first Subaru and overall she likes it.
I'm kinda handy and amazed how frustrating that car can be (sorry if I offend the loyalists... I just don't see why there's the fanaticism).
And side note if it matters... because of all the electronics / want to make sure car is running good and we expect to keep it a while, we paid extra for the 8 year / 120K / zero deductible extended warranty
I was replacing the OEM battery (wife didn't have issues with the battery dying issue / battery settlement) this weekend & took me on and off most of Saturday. I got a battery from Costco.
The issue is the negative terminal. Loosened the clamp and took the connection off the post. Along with the positive. Put in the new battery and connect the negative. I tighten it. and negative strap doesn't tighten enough / connector turns easily around post. Taking the connector off terminal, look at how it works. Not sure how tightening the nut actually would tighten the strap around the terminal?! Googling, I find loads of people talking about this. One person said they read on facebook that someone was told by a dealer that the connector is 'one and done'? Once loosened, you need to replace it?
https://www.subaruoutback.org/threads/negative-battery-terminal-replacement.541964/ and many others.
I wind up kluging this - using a hose clamp around the clamp after I took off some of the extra metal on the strap / crap clamp.
I did notice / wonder if the hose clamp can really take the torque to make the tight fit. and part of clamp metal doesn't lay against the terminal.
Car starts / works.... but it's my wife's car, don't want her getting stuck if hose clamp breaks.
some questions
1) Any advice on how to improve the connection if any?
2) I guess I need 29182AA11A ? About $50?!
3) Are there referral codes / discount codes / preferred dealers / websites to get parts?
4) Is this issue of not being able to reclamp the negative a common thing? Or just when you look for something on the web, you will find it / seems like a common issu?
5) Any info on why they made the clamp that way vs a more traditional horizontal screw / bolt arrangement?
6) And am I seeing things correctly? The positive terminal is a) a different design than the negative AND is 2 rings?! I'd think you want as much contact between the clamp and the terminal post? 2 Thin rings of metal?!
And am I wrong? There's a bit of fanaticism for Subaru? Is it waning over recent years? What am I missing?
Some of the issues we've had:
Windshield cracked 2 times from the edge (design issue?)
Calibration of eyesight costs more than the install and material of the new windshield?
Car broke down because of TCV failure (design issue)
Wipers are not the more standard / common clip design / costco michelin wipers don't fit?
Rear wiper is also a more unique connector.
Several other issues / quirks that raise the cost of maintenance, complicating things. Just to keep people having to go to dealer rather than a garage or self repair?
some questions
