Rear Light Wire Cokors
I am replacing the rear bumper reflectors with lights. My question is that the car has 5 wires and the lights have only 4. The seller said that i only need to use 4.
I just need to know what color wire on the car is the ground. I did this on my Rav4 but it only need 2 wires.
I am on many forums and there are 2 reasons why one gets views and no replies.
1-Don’t know the answer .????
2-Or it is a stupid question . ????
Or we have full days and a guy no one knows with a wire color problem is low priority. Give people a break. Forums are free info a dealer charges $250/hour for.
easy solution- invest $4.98 at harbor freight and get a volt/ohm meter. put the meter on ohms and with no power on touch a ground (frame) and each wire til the meter needle swings to 0
Whatever you do, don't use a cheap/HF meter for anything. You'll diagnose yourself into oblivion/madness with bad data. They're WAY off and get worse as the batteries wear.
for measuring if a wire is a ground, there's no reason to invest in an expensive meter. I have Fluke equipment and HF meters. Both measure a ground equally well.
So now you know me and i will be more patient from now on.BTW. I did get them installed via trial and error.
jade_nicole
