As you may already know, source of leak in those cases was at the disconnect, so 4 lines are in "rust zone", so their alternate method literally works around prob area. I am interested in using SS but have no experience in flaring either. I'll need fittings for joining pipes and more to reconnect near wheels. Car has been sitting for a year, 150 miles away so I have to try and bring everything I'll need to get her going, beyond ramps, jack stands, and floor jack. What size line and fittings, what tools to bend/flare, where to get ? Any chance they make flexible SS lines of various lengths with proper fittings pre-attached ?
99% of the time the lines break off where it goes through the floor under the back seat, its not too bad to get to once the seat's out. ive had to fix 3 of my subies in the past in that spot. flaring is intimidating but you can always cut it back and start over until you get it. solidarity from the rust belt lol2006 WRX has a leak in middle of back area .. very rusty, don't know where exactly. How can I locate and repair the leak ? Can I route a new line or section ? Any prior experiences can help me get started on this. Thanks, Ron
Did you run the new line under back seat like they did in the videos ? I'd think that some extra protection under the seat like running inside a fuel hose so its less likely to get worn thru. Think they make pre-fab flexible lines to specified lengths ? I'd still have to double flare lines going up rt side. I think dropping the tank to run that 1 line above is way too much work. Any tips on tubing type, size or fittings ? Appreciate thoughts & advice.99% of the time the lines break off where it goes through the floor under the back seat, its not too bad to get to once the seat's out. ive had to fix 3 of my subies in the past in that spot. flaring is intimidating but you can always cut it back and start over until you get it. solidarity from the rust belt lol![]()
i definitely wouldnt drop the tank haha that would be a headache. i just spliced them right above and below the floor, but i DID have to replace a gas line one time after i melted it welding (caught on fire, 0/10 experience don't recommend) and ran it under the seat that way. that was last winter on my daily, i havent had any problems with it. idk whereabouts you are but canadian tire sells pre-made pieces of different lengths with the flares and fittings, im sure other auto stores would have similar stuff. just might have to make a little loop under the seat if theres any extra line. i dont remember the sizes but if you take the old stuff in and eyeball it and just make sure you get the right thread pitch it should be fineDid you run the new line under back seat like they did in the videos ? I'd think that some extra protection under the seat like running inside a fuel hose so its less likely to get worn thru. Think they make pre-fab flexible lines to specified lengths ? I'd still have to double flare lines going up rt side. I think dropping the tank to run that 1 line above is way too much work. Any tips on tubing type, size or fittings ? Appreciate thoughts & advice.
Comment : when it comes to Brake-Line-Tubes , .... there is no such thing as "... a little loop..." !i definitely wouldnt drop the tank haha that would be a headache. i just spliced them right above and below the floor, but i DID have to replace a gas line one time after i melted it welding (caught on fire, 0/10 experience don't recommend) and ran it under the seat that way. that was last winter on my daily, i havent had any problems with it. idk whereabouts you are but canadian tire sells pre-made pieces of different lengths with the flares and fittings, im sure other auto stores would have similar stuff. just might have to make a little loop under the seat if theres any extra line. i dont remember the sizes but if you take the old stuff in and eyeball it and just make sure you get the right thread pitch it should be fine
