Hi all,
I'm just trying to figure out an overheating issue I'm having with my 2011 Subaru legacy...started overheating while running the a/c. Did a flush, replaced thermostat coolant and hoses, burped the system several times, everything seemed good. then today while driving, I noticed it started to overheat again only after I had tried to turn on the air recirculation inside the cab. I parked at a store, turned it off and let it cool. Topped off the coolant and started it back up. Ran the a/c on my drive home (about 20 mins, but also sat with the a/c on at idle for 10 mins before driving back) and had no issues. I got home and decided to double check my theory, turned the a/c off then turned on the air recirculation and it immediately start heating up. Oddly, even once I turned the recirculation off it continued to heat up...until I tried turning the a/c back on after which it promptly dropped back to normal temps. For now I'm planning to just not use the air recirculation but I'm honestly stumped as to how this alone could be causing an overheating issue. Just wondering if anyone had any thoughts on what might be happening here.
I've also noticed when it starts to overheat the heat in the car doesn't work unless I maintain high rpms, which leads me to think it's causing a flow issue, but again I'm stumped as to why the air recirculating button is causing this to happen. Esp as it seems to run fine as long as I don't use the recirculating setting.
Any help would be really appreciated, for now I'm just not going to use the recirculation but I'd love an answer as to why this is happening.
Thanks!
Thanks!
