Outback TPMS Refresh
I have a 2019 Outback with 48,000 miles. The TPMS light is now flashing now and then. All four tires are inflated to the proper pressure so it must be the TPMS battery in each tire. I was quoted $350 plus about $440 in parts to replace all four sensors and batteries. That is nearly $800!! Is there any cheaper alternative to having the dealer do this? Third party TPMS monitors or tire store service personnel?
Wait til you replace tires which should drive labor close to zero.
Yes. Unfortunately, the tires were replaced last year and still have years of life on them. I plan to check with the tire store to see if they can do the job cheaper. I was hoping someone had already down that and could advise me appropriately. Also - at $104 per tire for the monitoring device, there has to be a less expensive solution!
Yep. Unless there isnt. Good luck.
Hi! I work at discount tire. tmps sensors are $69 before tax. Ballpark after install is probably around 290 bucks. But if you buy some online they will install them for about 50 bucks and reprogram for free.
Edit: The sensors also come with a 70k mile warranty or 6 years.
THANKS! This exactly what I was looking for. I bought my new tires at Discount Tires and was planning to ask them about replacing the sensors! I found OEM sensors on line for under $40!
Costco charged me $45 each for sensors when I bought tires. They only charge about $50 for a snow tire swap, so presumably if you go there, It should cost less then $180 + $50.
ETA, $40 for OEM is good.
Costco charged me $45 each for sensors when I bought tires. They only chard about $50 for a snow tire swap, so presumably if you go there, It would cost less then $180 + $50.
Thanks! Appreciate the insights!
msb
