This year I traded-in my 2021 Forester Touring for the 2025 model. Although there are new features that I like there are several things where I think Subaru has gone backwards. The one that bothers me the most is “Repeat Facial Scan”.
On the 2021 model it took two or three (I’m old – I don’t recall which) button-pushes to re-scan the eyes. It’s something that I usually do once or twice a week. This is necessary when you have gotten into the car and been occupied with tasks and the scan times-out. On the 2025 model it takes six (per the manual) or seven.
From the manual: (1) Touch the home button. (2) Press settings. (3) Press the Car tab. Note: if the Car tab is not showing you first have to press the right arrow. (4) Press “Driver Monitoring System”. (5) Press “Repeat Facial Scan”. (6) Press OK.
The reason I think that it should be different:
There is a button on the screen showing “driver profile icon”. Pressing this button serves only one function – adding or editing a driver to the system. It is very rarely used. On my 2021 model I used it once to add my wife to the car – on the 2025 I have not needed it because she doesn’t want to drive it. It would make much more sense for that button to tale you to the screen that step 4 above takes you to. That screen has several options in addition to Repeat Facial Scan, including "Register User".
For Subaru to change it would require a relatively minor software change. It just makes sense for it to work that way.
