Multiple lights and codes on my 2020 base Forester - please help!
A month ago I briefly smelled something very sweet like a coolant leak so a nearby mechanic tested it and put in a new valve cover gasket and 4 plugs. A week later as I pulled out of a parking lot, all the dash lights came on. I got it home and we get these codes - P0971, C1431, B14A1 and B2801. The Eyesight recently had been intermittently flashing on the screen. The right front wheel well has a crackly sound at low speeds (maybe does it on the road but I can't hear it). Not sure how many issues I actually have - do I take it to a transmission shop or a mechanic, could it be faulty wires, I just don't know where to start. I feel like I should tow it because I'm afraid to drive it. My money for repairs is very limited, and being a female who knows little about cars, I don't want to get ripped off by someone who will just throw parts at it. I have almost 120K miles on it, purchased new, and it is due for brake replacement also, if that is relevant. If I fix one problem, will that fix the other problems? How could I have four different issues start at the exact same time? Many people won't touch a Subaru, so that makes it more difficult to find a mechanic. Thanks for your help!
Yes, you have every right to be suspicious of general mechanics. I notice that replacing the valve cover gasket and sparkplugs has nothing to do with a possible antifreeze coolant leak.
The P0971 is a common Subaru problem. If you have a question about any DTC codes, check YouTube for the answers, even if you want a mechanoc to do the work for you.
It seems to be a problem with a solenoid in the transmission.
Here is such a video link:
You have a parts swapper with a boat payment coming due, not a mechanic. Find a decent mechanic.
Dear dsmith,
you asked about all of those codes suddenly appearing. That is also a very important clue!
Computers function by controlling the access to Ground.
The various computers and sensors on a car have one thing in common: they all require a good Ground connection!
Before assuming the worst, check the battery connections.
I suggest checking the battery terminals for corrosion.
A visual inspection may help, but that is sometimes insufficient, and sometimes the corrosion and resistance are invisible to the naked eye
Use a good voltmeter to check the Ground connection at the battery terminal, and away from the battery terminal, such as the engine itself.
See if you still have 12 volts. If you do not have a scan tool, then go to an Auto Parts store like Autozone and have them erase the DTCs for you.
It might be as simple as Cleaning the Battery Terminals.
If the Diagnostic Trouble Codes come back again, then maybe you do have a problem with the solenoid in the CVT.
Good Luck!
Here is even more information on YouTube about the solenoid valve body in a Subaru CVT:
It is important to realize that there are Options Available, whereas the money in your bank account is limited, right?
I recommend finding out all you can about this problem --before you spend your hard-earned money.
I do not have a CVT myself, but I continue to find problems with the approach to fixing them. Before you pay someone, learn what you can via YouTube. It might be more simple to fix than first imagined.
jade_nicole
