Iphone 18 doesn't work correctly with Carplay
Hi, Anyone else having trouble with the new Iphone18 and their Subaru charging/carplay?
Got the new Iphone18. When charging thru the USB ports, the phone would start charging, then stops, a few seconds later starts charging again. This process over and over. Its the same with carplay, comes on, turns off, comes on turns off. Its not the wire, I bring the wire to the wall outlet, computer, other cars and it charges fine. I bring other older Iphones, 14 15 16 17, they all work normally in my Subaru. Only the Iphone 18. I've tried it in other peoples car, like the Lexus and Toyota, the charging and carplay works fine, so it shouldnt be the phone itself. Could it be the software in the Subaru, ive checked and its up to date. Guess we need a new update?
In the meantime, to charge the iphone18 in the car, I have to use a adapter and plug it into the cigarette lighter.
Do you have a thick case? I have the Otter Box Mag Safe and I sometimes have to move it around on the tray to get it to charge. With the case off, no problem.
No problems at all with CarPlay connectivity.
I have a 16 Pro.
Hope you get it figured out!
jade_nicole
