i just used a meter-11.3 volts.Did you diagnose the charging system or just installed an alternator?
battery has stayed over 12 volts over a period of several days and has started the car several times battery 1 year old. with engine running 11.3 v across batt terminalsAnd the battery when disconnected from the car, and after a full charge then waiting 24 hours?
12.0 volts is a dead battery. They are 2.2v per each of 6 cells.
I'll do that, thanksGet it properly diagnosed. Parts are expensive.
