Hey from TX
Hi all! I'm Noemi. I just bought a 2023 Blue base models Forester. This is my second one and I love it!
I had a hand me down legacy for awhile before I got a GMC truck for work. Now I'm back to subaru. I've had to learn my way around repairing corollas and GMC trucks but now I need to learn how subaru are set up.
Question. Are most regular fast oil changing places set up for subaru? I just saw there is a one time use o-ring or clamp used in the oil change. Thank you!
Noemi ~
The majority of "regular fast oil change places" lean toward the cheapest available engine oil and filters that will physically fit the filter attachment place. None of that makes them good for your vehicle. And they may or may not be inclined to change the drain plug crush washer which really is important.
My preferred approach is to settle on one brand and weight of engine oil, one top-notch filter, and OEM drain plug crush washers and take those products to a garage or dealership who will do the work.
Dave's advice is sound. We've all heard/read horror stories of quick lube oil changers draining the transmission then overfilling the engine oil with transmission fluid, cross-threading the oil drain plug, never using a new crush washer, and using 2 bolts, or leaving it entirely off, the lower engine cover.
Subaru filters have specific specs. There are a few maker/models that are the same/similar, but most aren't. Nearly anyplace will install a Subaru filter you bring them with whatever oil you bring or they already use.
And...oil changes are SIMPLE. Maybe try it on your own? You get a good look around for leaks/problems while you're down there. I can do mine in ~15 minutes.
Looks easy online. I just need the 2 car jack stands and a think to catch the oil, right? I really don't want the oil changers messing with my air filters, They broke the plastic bits off my toyota inside filter.. And don't want to take time off work to schedule with the Subi dealer here.
Search YT for your make/model/year range.
Gain access to filter/drain bolt.
Drain oil.
Remove filter.
Let all oil drain.
Wipe surfaces clean and ensure old gaskets aren't still on there.
Use new drain bolt gasket if old one isn't reusable style.
Tighten drain bolt and filter to spec.
Add proper amount of proper oil.
Run a few minutes and look for any leaks.
Button it up!
Smart move, order Subaru filters and a pack of crush washers online and get the oil from Walmart.
You can take the used oil to Autozone
msb
