Hard Wire iPod to 2006 Legacy
Jim (11)
Usenet Archive
Anyone know how to? Whats the back of the factory stereo look like? Any cd changer input?
Which model Legacy.Does it have the integrated CD changer/climate control? If so, it is complicated. This is discussed widely on the LegacyGT.com discussion board.
I think the easiest way is to use an in line FM modulator that plugs into the OEM head units antennae.It needs adapter cables. The Subaru's don't have aux.in plugs. If the headunit has the ability to control an add on cd changer then the input plug for the changer can be used to input the Ipod. Subarus have not been add on Ipod/MP3/Sat radio friendly.
My XM is wired to the radio using an FM modulator and 2 adapter cables, sold as a pair by Metra. But it is the 6 cd changer with integrated climate(Legacy GT).My daughters Impreza RS is set up like mine and it has the standard single cd headunit like yours.
Audiophiles say the fm mod setup is inferior to a direct in and they are probably correct but I am not cursed by the audiophile bug so the sound is plenty good to me.Much better then the broadcast FM mod that is sold as a solution.
Cheers
I use one of those broadcast dealies, and I'd have to agree. How does this FM mod setup work? Does it always take a particular channel?
The Fm modulator is installed behind the head unit. The line out from the device(sat radio, mp3,ipod,etc) runs to an adapter cable, then to the fm modulator. The signal leaves the modulator through another cable adapter to the headunit. The cars antenna plugs into the fm modulator as well. The modulator also supplies power to my xm radio but that is specific to the XM unit.The fm mod unit has several frequencies which can be changed to get the cleanest signal. The modulator also has a shield to prevent frequency bleed over in areas whre there is a lot of fm signals to interfere. Inmy community this isn't an issue but when I drove to DC I couldn't use the broadcast fm modulator in my Roady@ because I couldn't find a free frequency..I leave the headunit set to
87.5 whenI use the XM. Additionally,I can use the set up to play an MP3 but just pulling the line out(headphone) plug from the xm and plugging it into the mp3 headphone plug.It plays thru the radio just like the XM.
I recommend professional installation unless you are comfortable pulling out the radio. I'm not.
Cheers again
sdes2003
