Grinding noise when turning sharply
Manuel Freitas
Ok, I've searched the archives and found similar posts and answers,
but not quite what I'm experiencing. I have a 99OBW that is making a
grinding and shuttering noise when I do a sharp turn like getting
in/out of a parking space.
It kinda vibrates too. But here's where I find this to be different
from other posts I've seen here: It only happens after I've driven the
car at reasonable speed and a reasonable distance, like 15 miles on
the highway.
This doesn't happen at all when the car is cold in the morning, or
after driving the daily 5 mile commute to and from work.
Any guesses as to what could be causing this problem?
- Manuel.
the highway.
Check your tires for even circumference/inflation.
If they're okay, your center differential may be shot. If it's a manual
transmission, it is the transfer plates and silicone inside the viscous coupling -
as the components warm up, the differential starts to bind, causing these
problems when cornering. The automatic has amore complex system, but the
principle is the same, though.
I had the entire transmission assbly swapped out with a nearly new one from the
junkyard ($450+ labour) on my 95 Legacy and that fixed it.
florian
How many miles on the car?
Does it happen when the wheels are pointed in both directions or only one
direction?
The first thing that comes to mind if the car has more than 60K miles or a
torn CV boot is that the CV joint has just started to fail- hence why it
only happens under certain conditions.
If it is the CV joint it will eventually make noise under all conditions
when making a sharp corner.
(e-mail address removed) (Manuel Freitas) wrote in
the highway.
Sounds like the CV joints are going bad. Are there oil drops underneath
the wheels? If there are,the CV boots have torn & you'll need knew CV
joints. Happened to my Subaru. There is a clicking sound when you make a
sharp turn.
My 'guess' would be that insufficiently lubricated parts have
heated up to a point where it becomes noticeable.
My Subaru dealer explained how to relieve a similar scenario.
Find an open parking area and make very 'slow' wheel to wheel
figure 8's, at least 5-6 times. Turn the steering wheel as far
as it will go in each direction, fairly quickly so the figure 8's
are as small as possible. That's why you do it slowly so there is
no chance of damaging anything and you are not leaving ugly rubber
marks on someone's parking lot.
Try this for at least a few days and see if it will reduce or
eliminate the 'bucking when turning'. Hot or cold shouldn't matter
as you are trying to get the 'ends' of the transaxles lubricated.
The dealer said this was not an uncommon problem if you seldom
have a need to turn the steering wheel to its end points.
If the CV's are not cracked or leaking, the bucking when making slow,
sharp turns does not indicate a problem in need of repair. My '95
Legacy wagon developed bucking at 55k and the transaxles weren't
replaced until 118k. My 800' solid rock driveway had a 25% grade which
is what 'did-in' my transaxles. I was surprised they lasted that long.
HTH,
BoB
I had the exact symptoms as Manuel on my WRX. It was the center differential dying.
dying.
<snip>
Thanks Andrew and Estelle!
I thought I was the only one here.
To the original poster:
When I researched this problem for my own Subaru, I also got quite a few replies
pointing to the CV joints.
The mechanic(s) first thought it was the clutch pin bearing, then the CV joint,
then the drive shaft/universal. You can burn through a fair bit of cash
following the advice of other people - however well intended. In the end It's
you who drives the car most, and it makes sense to develop the skills for
isolating problems yourself - even if you don't intend to get grease on your
hands yourself.
In this specific case, try the following: drive the car until warm. As soon as
the problem appears on dry pavement, try cornering the car on sand (wet grass or
similar). If the symptoms go away or appear less severe, you can safely assume
it's the differential.
florian
The lesson to be learned here is to let the mechanic tell what the problem
is. After all, he's right there under the car, or road testing it, or
whatever. He's not siting in front of his PC reading the input from someone
who is trying to explain what something sounds like, smells like, looks
like, or whatever. If you provide this kind of info, and someone advises you
to tell you mechanic to replace a certain part, he will be glad to, and if
that's not the problem you have only yourself to blame. If the problem seems
to much for your mechanic then take it to the Subaru dealer. He probably has
a service bulletin, and it may be a repair covered under warranty or recall.
For those people who actually work on thier own cars who happen to read
this- never mind, you already know to take all advice with a pinch of salt.
Stephengbear
