Full time DC power to the rear lighter socket in an Outback
I would like to know if it is possibe to get DC there without turning on all the other things that go on when you turn on auxillary power. I want to charge my RC plane batteries without running things down. (2020 outback Touring)
You could just run a live wire there...but you'll always be risking a dead battery if you, or anyone else, leaves something plugged in. You could also just add a live port anywhere in the car.
Thanks but it would be hard to snake a wire from the battery all the wasy back there. I was hoping to maybe run a jumper from a live spot to one side of the fuse holder going to that with maybe a seperate fuse after removing the fuse that would normally give it power when accesory power is on. but I would need to know that fuse is only for the DC socket.
Thanks that looks handy but I still need to find out if the DC socket in the back has its own dedicated fuse so I wouldn't be adding full time power to anything else. Any links to an electrical diagram that might show this. I didn't get a printed manual when I got this car used.
I must be missing something from your notes. Amps are pulled not pushed. Manuals are available....everywhere if you have access to Google, FYI.
I think I have it, Google Gemini helped. Remove one fuse from an always on circiut and replace with one of the "add-a fuse" adapters (put the apropriate fuse in that and also the one from the next step). Remove the fuse for the rear 12v socket to isolate that circuit from being on with accesories and put a small male blade on the end of the pigtail from the "add-a-fuse" and connect it to the side of that empty fuse holder that is not live when accesories are on. This should work as long as I am not powering anything else full time.
The manual is a little wierd with the 3 cigarette lighter type sockets, It seems to call one fuse "cigar" and the other connected to (2?) "12v DC" And then it goes on to state one should never plug a cigarette lighter into any of these? Maybe it just means the console and rear ones.
bmart- not sure where you got the amps pulled not pushed but I may have used a wrong term.
Cigarette Lighter is fused at a Lower PULLING-Level (10-15-Amp) , than the Power-Supply Outlet .... which can pull (if I remember correctly) is Fused @ 20-Amps Capacity.
You should be able to find this Info in your Driver Area Fuse Block (Driver's Left Knee ) ; Pull the Cover, and LOOK for the Fuses by Name ... !
This then will also give you direct access to the Wiring going directly to the Rear Socket , without having to run new Wires ......
Again , GOOGLE for your Fuse Block info ... the Internet is full of these tidbits ... just need to search and review options till you find the one for your Make-Model , then PRINT IT OUT for future uses , as you will need it if you blow anything up by guessing ... !
Install a portable battery with an inverter in the back. Connect it to the 12-volt outlet in the back. It will charge whenever the car is running. You can now charge your RC without risking running down the car battery. Additionally, you can charge USB devices or use 110V power if needed. Or even jumpstart someone's car. No wiring modifications!
Dan, the portable battery in the back would need a charger so it wasn't getting power once full (like the regulator for the standard battery) would it not. Or at least a battery tender (DC) of some sort. Unless when you mention "portable battery" you mean a device with this biult in?
Confuse the Imagination , ... with facts !!!
Oh, sorry I meant to say so it isn't getting power once full
A permanently hot outlet would be handy. We have a 12v cooler, and a previous vehicle (my bride's Audi) had such an outlet in the cargo area. We also had an inline sensor that would turn off the power if it detected too much of a drop in battery power. It never caused any trouble, and it let the cooler work when the car was stopped.
Dan
jade_nicole
