Front LSD on '00 OBW Ltd
John (2)
Usenet Archive
Hi All, my wagon has the all weather package so the rear diff is limited slip, but is the front also a LSD? I plan to change both front and rear diff. gear oil but the only flavor of 80W/90 GL-5 I found had the label limited slip on it. 2nd question: whats the difference btw the limited slip gear oil vs.non-limited slip oil?
Front diff is 'open'.
Don't think the gear oil matters.
maybe someone else can confirm.
also, check this link for info;
http://forums.nasioc.com/forums/showthread.php?t=995498
Front diffs are normally not LSD exept in modified vehicles. LSD oil has special "internal friction" and can endure more heat. It may be beneficial in a manual gearbox with worn syncro rings, and I do not think it will wear a non-LSD diff, but I would leave that to the experts.
Asbjørn
skookgirlrnpanj
