Front Left Lower Control Arm Bolts
Hello, I'm John and new to the forum.
I am in the process of replacing the front left control arm. To remove it, it was necessary to cut the one mounting bolt that passes through the fame vertically and up through the bushing on the control arm. It appears to be a specialized bolt that has a bit more girth close to the bolt head and tapers down a small amount for the rest of its length. I a trying to locate the part number of the bolt to purchase a replacement. Does anyone on the forum know what the part number is? Not sure if it is a Subaru only part of it can be purchased from another source.
Thanks, John
All, in case anyone has run into the same situation (2014 Outback Premium; sorry left that out from my initial post), the Subaru part numbers for the vertical front control arm are as follows:
Bolt: 901000346
Nut: 902330006
~$15 for the set.
Thanks, John
jade_nicole
