Front driver side window switch issue
2018 Impreza 50th Anniversay Edition
Seems the driver side window switch is having an issue when pressing down (to lower window).... it seems stuck when trying to press it... I have to fiddle with it. Going up is ok.
I also broke off (partly) the little silver tip. I did perform the "reset" but I think it is just a worn switch.
It seems form other threads I need to replace then entire switch panel and cannot just replace the switch itself.
Seems to be a screw in the door handle, then I need to pry off the door panel. Seems pretty easy fix....?
Thoughts?
This seems to be the replacement... but not sure if I can get it other places cheaper.
https://www.subarupartsdeal.com/oem-2018-subaru-impreza-power_window_switch.html
I have seen an alternative on ebay but suspect of that...
Both of my 2005 Legacies arrived with broken driver's window switches. Hard to activate. No way to modulate. The Ebay ones have been great. If you're handy, you can take them apart to see what is wrong...but no way to source the small parts, so it would have to be repairable by you with whatever you find in there. Be aware that they came come apart from the inside of the door cards like mine, not pop in from the outside...that would be too easy. :)
Donna P
