Visually inspecting the coolant. I look mainly at the clarity. Coolants come in different colors, green, orange, red, and blue, but they are all clear, like looking through a tinted glass or cellophane. You can look at fresh coolant coming out of the bottle to see what I mean. There are other tests that are more precise such as a pH test. The pH test is probably the best but it requires equipment or test strips.
You should have a coolant tester, but that does not test the condition of the coolant, only its concentration, I.e. 50/50 (50% coolant/50% water) or 70/30 etc. But it does allow you to see the clarity of the coolant through the collection chamber. And these are cheap.
There is a voltage test that you can do, there are plenty of Youtube videos on this but I am not a big fan. Too many variables can throw off the results, especially the condition of your battery and the grounding system in your vehicle.
Considering the age of your vehicle, replacing the hoses (all the hoses including heater hoses and any hoses used to heat up the throttle body) is a good idea. Coolant isn't cheap so it would be a shame to do all this work only to have a hose leak in a couple weeks/months after and lose all that new coolant on the side of the road. Same for the thermostat but I would wait on the water pump. But, not funny story, I did a coolant system service on a car with 275k miles, replaced all the hoses. Did not replace the thermostat because I had just done that a little earlier that year due to CEL. Hardly a week later and the water pump started leaking, but that only ever happened to me once.
Since you used a chemical flush, I'd recommend getting both of those drain plugs out and flush the system with as much water as you can. The OCD side of me wants to use distilled water but the truth is that if you are flushing with a garden hose, that tap water will not be in the engine long enough to leave behind any minerals. Maybe at the end, lightly insert the plugs and fill the system with distilled water one time and drain, but get as much as possible drained out.
I recommend that you use genuine Subaru coolant. It may not be any different of better than aftermarket Asian coolants, but for very little extra cost (a few dollars spread out over the next 100k miles) you have that peace of mind. A good nights sleep has value too. Also use OEM hoses and hose clamps and an OEM thermostat if you chose to replace that.
If you use premix, OK. If you buy the concentrate, then mix with distilled water. Mix in containers outside the cooling system and then add, do not estimate volumes and hope they mix OK in the system. If you do your own mix, it is OK to go a little rich, up to 70% antifreeze but that doesn't really have any value in most of the lower 48. Good luck.
