Data Communication Module (DCM) update? - dead battery....
Original battery died (2018 Impreza) in June. Bought new battery then and came back from 1 week vacation this week, and battery was DEAD. Had to take it back to store for charge as jumping/charging would not work it was so dead.
I read online that the Data Communication Module (DCM) (we are NOT subscribed to Starlink) can drain the battery... the warranty was extended 8 years but local dealer tells me it expired in June 2026 for us.
I am guessing the DCM is draining the battery (nothing else in car has changed or drains battery).... and there is a software update I read can be performed...Factory Bypass Mode (stop the car from accessing the 3G network).... however local dealer want to check out the entire car first ($$$$).
I get the battery back today and understand I can check if the car has the Factory Bypass Mode update...if the Green Telematics LED is illuminated...
If it is then something else is draining the battery... if not I need to do the update.
Is there a way to do this myself? Or do I need to use a dealer?
Thanks!
Follow up... the battery is charged at shop.. and the green light is on in the car (when on) that means the DCM is still working and draining.... dealer now says they can fix is for $220 (stop the DCM from signaling)...
jade_nicole
