Clunking while turning
Hello all,
I have an '06 Forester X with the 4AT doing something that's stumping me. When it is cold (hasn't been driven for at least 20 minutes), there is a pretty significant clunking coming from the drivetrain when turning in the parking lot (feels like it's coming from the rear wheels, but can't be sure). After it's been driven for a while, it goes away. It happens when moving forward or in reverse, left or right turns. It feels like a locked rear differential making tight turns on dry pavement.
This is my first AT Subaru. With my MT Subaru's, I would associate it with a failed viscous coupler, although my experience with those is that the problem exists after diff warms up. As I understand it, an AT does not have that same viscous coupler. I'm not sure if this is a transmission thing, or a rear diff thing. The rear diff fluid is full and clean. Same with trans fluid and center diff fluid.
Any advice for how to track it down?
Thank you.
Hello all,
Thank you.
Does it make a difference which direction you are turning?
No, it makes no difference. Both directions when turning sharp at slow speeds, like pulling in and out of a parking spot.
Transfer clutch lock up?? I'm going through this same issue myself right now on a 2016 Forester. Changed two bad solenoids on the valve body and everything was great for about two days, then started experiencing the low speed turning lock up. I did not do a transmission re-learn because I don't have a fancy scan tool. I'm hoping having a shop do a re-learn may solve the issue. What do you all think???
Two ball joints is unlikely, but there's the viscous coupling that does that. If it is bad, find the cause before replacing it.
JoeCho
