A
alf
First I am really satisfied I did it on my own. Quite an easy procedure.
For the record - car has got 94K miles on it. Here are a few
highlights/questions:
1- in order to release the line pressure (enforced by ABS), I read
somewhere to depress brake pedal 10-20 times before the job. So I did
it. But does it make sense?
2- the OEM brake pad kit purchased from the dealer did not contain the
grease (as opposed to front pad kit I got some time before). So i did
not apply anything, is that okay?
3-pushing back pistons 1: I wish I had the special spreading tool (are
such available). C-clam did the job but it took some time to learn how
to do that.
4-pushing back pistons 2: I did it very slowly however read somewhere
that the fluid can come out of the reservoir or somehow it is easy to
screw up this part. Is it really a deal here (in case of subies)?
5-the nuts - what is the torque value for caliper bolts? I mounted them
quite tight but since I have torque wrench, I would like to make an
use of it.
6-it was a last call to change the rear pads (first time in the cars
life). They were worn out almost to the metal. Fortunately, the rotors
seems be in perfect condition.
Regards, Andy
to do that.
use of it.
Regards, Andy
