Andy said:
How often it should be changed to provide optimal performance yet
guarantying the long lasting life.
I've owned exactly one automatic in my life, and it's not my Subie! It's
a Toyota Camry. Toyota recommends changing at 30k miles on my car. The
previous owner was an absolute stickler for maintenance (wish she'd
owned my Subie before me, too!) and had the trans fluid drained and
flushed (where they run 12-15 qts of fluid thru to really clean things
out) every 15k miles. The car had 214k miles when I got it, and 228k
now. No trans problems so far... (he says, knocking on wood!)
I've taken a different tack on this, based on what a lot of Toyota
"fans" have told me: instead of waiting until 15k or 30k, I change the
fluid every second oil change (around 7500 miles.) This particular car
only releases 2 1/2 qts when you drain the trans (I haven't a clue
what's still in the torque converter--my book says nothing on the
subject), and it's easier than changing the motor oil and filter
(there's just a drain plug, no replaceable filter that has to come out
when you drain the ATF.) Judging by the stick, the fluid actually seems
to stay cleaner than going the 15k miles. I don't know what happens when
you drain a Subie trans, but this is a regimen you might ask about.
Friends of mine owned a trans shop for years, and they told me you
should follow one of two regimens WRT changing fluid: change early and
often, or not at all. The reason behind the latter recommendation was
that if you don't change for a long time, then all of a sudden decide
it's time to start doing some "preventive" maintenance, you may be
opening up a can of worms with old crud breaking loose in the trans with
new fluid. Naturally, the trans will last far longer with the "early and
often" regimen.
So judging by what they told me, I'd guess you won't hurt anything by
changing often, but will probably shorten the life of the trans
considerably by not changing often enough.
