Update:
Just got the car back from the mechanic. The mechanic ran the pressure test
and said the car has a leak via the left front engine gasket. Just like the
post in 6-13-2003 by DYM. I still have 8000 miles before my limited
Powertrain waranty expires so I schedule an appointment with "Don Beyer
Subaru of Alexandria" for a waranty repair.
They are also going to do the recall service job that I got on the mail.
This repair job has to be covered becuase the waranty reads as follows:
Powertrain Limited Warranty
Powertrain coverage for all models is five years or 60,000 miles,
whichever comes first. It covers the major powertrain components listed
below:*
Engine block and all internal parts
Cylinder heads and valve trains
Oil pump, oil pan
Timing belts or gears and covers
Water pump
Flywheel
Intake manifold
Oil seals and gaskets
Torque converter
Electronic transmission control unit
Transaxle seals and gaskets
Axle shafts and constant velocity joints (except boots)**
Propeller shaft
Therefore either the "Engine block and all internal parts" or "Oil seals and
gaskets" clause should cover it. Right?
--Joaquin
TG said:
I have had most of my Subaru coolant leaks show up in the morning to begin
with and then get worse. I don't think the incline had anything to do with
it.
Stop worrying until it gets worse or have a pressure test done. TG
Joaquin Rosario said:
Update:
I put the car on a ramp, removed the plastic under-cariage protector on
Saturday and inspected the radiator as well as the lines and they all looked
good. I went through every line that connected to with the radiator and I
could not find any moisture. I had the car running for 30 minutes
(while
on
the ramp) and nothing leaked. The area where there was an accumulation of
antifreeze was right under an internal fan area. I looked and looked
and
I
could see anything leaking. It was strange, my feeling is that it's
something within the confines of the engine.
Furthermore, I ran the car the entire weekend, and not a drop. I even
placed a big newspaper under the car to trace the leak, and there was
nothing.
However today in the moring it started leaking again. The only things the
comes to mind is that I parked it a driveway with an incline and that this
morning it was in the 60s. Also, maybe it was antifreeze that had
accumulated between Saturday and Sunday.
--Joaquin
plate
