Maddy
The check engine light came on in my Forester. I got the diagnostic
code, PO106- manifold absolute pressure/barometric pressure circuit
range/performance problem. The Subaru technical site had a bulletin
concerning the air flow meter sensor.It stated that the element becomes
contaminated with Silicon oil, Carbon and dust at the sensor base
causing a malfunction. My question is, where is the air flow meter
sensor located? Is this something I could access and clean? Any help
would be appreciated. My state requires emission inspection and if the
check engine light is not turned off it will not pass.
