L
lee8321
TOPTEN Electronics Technology LTD (www.gpscaralarm.com) is the
professional manufacturer of car alarm http://www.gpscaralarm.com &
GPS tracking device http://www.gpscaralarm.com/news/ from China. We
produce GSM http://www.gpscaralarm.com/car alarm system,
http://www.gpscaralarm.com/GPS_tracking.htmGPS tracking system,
wireless car alarm & Mini GPS tracker http://www.gpscaralarm.com/GPS_tracker.htm.
Our products are much better than normal http://www.gpscaralarm.com/car
alarms. It is not only a GSM car alarm http://www.gpscaralarm.com/GSM_car_alarm.htm,
but also a precise GPS tracking device. You could monitor & protect
your vehicle by your mobile at any time & anywhere.
The functions of our GSM car alarm & GPS tracking system are as
followings:
(1) In case of theft (car is shocked, car door is opened, engine is
started or power supply is cut off), the car alarm will send SMS to
your mobile or call your phone, reporting the position also;
(2) You can exactly locate the car by SMS, and get the data
information of GPS tracking system (latitude & longitude, speed &
direction), no need to pay additional fee;
(3) You could monitor the voice around the car via telephone;
(4) You could send SMS instruction to the car alarm, then cut off the
car power/fuel supply, so as to stop the car;
(5) You could check the car door's status, engine's status, car's
location, speed & direction by SMS at any time;
(6) In case of hijack, you could press anti-robbery switch, the car
alarm & GPS tracking system http://www.gpscaralarm.com/GPS_tracking.htm
will send out SMS message for help;
(7) Central lock automation, you could lock/unlock the car door by the
transmitter or by phone;
(8) Mute-arming function. When the car is mute-armed, once the car
alarm is triggered, there is no signs around the car, but the car
alarm will send message to user's mobile;
(9) If the backup battery is low, the car alarm & GPS tracking device
will send SMS to warn you;
(10) This GPS/GSM car alarm & tracking system is design with back up
battery, stable and reliable & anti-tamper;
(11) In the place where there is no GPS signal, the GPS vehicle
tracking system http://www.gpscaralarm.com/GPS_tracking_device.htm
will display the latest data of the place where the GPS signal
disappeared;
(12) Two kinds of location information, user could locate the precise
location by GPS device. At those place where there is no GPS signal,
user could also locate the car by GSM network.
(13) Flexible design, the GPS/GSM car alarm http://www.gpscaralarm.com/GPS_car_alarm.htm
& tracking device can work alone without any management center, user
could track the vehicle by the help of Google Earth. If he want a much
stronger function, he could use the service of the management center;
(14) Distributor can set up a management center to supervise & control
many vehicles conveniently. If the management center (Management
software, GSM Modem & MAPINFO map is needed) is set up, user could get
the friendly physical address by SMS. Distributor can provide this
service and charge the fee from the end-users;
(15) If the car exceeds the limited maximum speed, or the car gets
cross the certain territory(=Geo-fence), the system will send SMS to
warn the user. (Optional function of the management software);
Contacts: www.gpscaralarm.com , Tel: (+86)20 87515322,87562958
(e-mail address removed) , MSN: (e-mail address removed)
followings:
disappeared;
