A bunch of warning lights came on at the same time
2014 Forester Premium 2.5i. Today while we were driving on the freeway at about 75 mph the car dropped out of cruise control and spit out all of the messages below and lit the accompanying lights on the dash.
  • ABS needs to be checked
  • Vehicle Dynamics Control system needs to be checked
  • Hill start assist system needs to be checked
After doing some reading, it sounds like it might be related to a bad brake light switch, a wheel speed sensor, or low brake fluid. Not sure if this could be related, but the driver side passenger brake light has a crack and has some moisture in it. I didn't think to check the brake lights until later after I had turned the car off, when I turned it back on, the warnings were gone. Each brake light has two red bulbs in them, all of them other than the bottom one in the one with the crack light up when I press the brake pedal.
I know there's a recall out for the brake light switch for 2014 Foresters, not sure if the brake light switch could cause these symptoms though, and the lights work when I press the brake.
The brake fluid is about halfway between max and min.
What do you guys think is wrong? I think I might start by replacing the cracked brake light and the brake light switch, I know Subaru would replace the switch for free, but I'd have to drive to and wait around at the dealer for them to finish.
Edit: Doing some more READING, it sounds like it's likely the brake switch. It looks like THIS is the kit I would need?
Wondering if Herpderp was able to fix the issues and how? My 2014 came up with the same warning lights and dropping out of cruise control?
Check all your lights. Mine did the exact same and it was brake light bulbs
Sometimes there are individual problems that are not related to each other,
so each problem should be checked.
If your warning lights go back out, it could be called a "spurious" problem in the circuit, but, if it comes on again, then you definitely have a problem. Were you braking heavily at any time during your 75 mph cruise?
On a recent drive to the Coast, most new cars were doing 90 mph and tail-gating asif they knew nothing about inertia.
Always give yourself a safe distance on the freeway. Too many young drivers have npo idea what a safe distance is! Just remember that an emergency also requires a good reaction time.
I have had ABS come on when there is a leak in the brake circuit.
The brake fluid should be full, so there is a problem with Herpderp's brake circuit. If air enters the system due to leakage somewhere, the ABS light will come on. Air is bad for hydraulic brakes because air is a compressible gas and hydraulics works on the principle that it is an incompressible liquid.
Old brake fluid can absorb water from the humidity in the air, but this should not happen because it is a closed system.
Also, water can turn to steam, due to heat at the brake discs, so I would suggest 1. look for leaks, 2. flush out old brake fluid, 3. bleed the brakes to remove old fluid and air that may be in the system. Leaks normally occur at the wheel cylinders, but also check the flexible lines for damage or degradation.
Wheel bearings usually make a noise when driving, and it sounds like a constant humming noise. If a front wheel bearing goes bad, it is a good practice to replae the wheel bearings on both sides because both sidess have the same mileage. Sometimes, in order to save money, owners only replace the side that caused the objectionable noise, but that would be "living on borrowed time", since the other side usually acts up sooner or later.
Bearings can get loose and one can check for looseness by jacking up the car and checking for play with hands at 12 and 6 o'clock on the clock. If the looseness is at 9 and 3 on a clock face, then it could be your tie rods. Young people are beginning to forget what a clock face looks like because nowadays they only see digital numbers on a screen!
My 1010 Forester had a similar occupancy with what looked like every system failing. It turned out to be some stupid control valve some bone head invented to replace the thermostat. It controls water temp so if it fails it could be in open or closed. Open you have no heat which is ok, closed you'll overheat. Was a recal and repair are free which is good because it cost$1500
Applologies, can't remember the exact technical name but check service bulletins. Good luck
Yeah, but now they all came back on for another problem, now I think its my wheel bearings
So I took the car to a Subaru dealership as it started misfiring on top of displaying the above mentioned lights (ABS, Airbag, Stability Control, Hill Start. They ran diagnostics (cost me $214 just for that, ugh) and here is their heartbreaking findings (posting here in case someone else is running into the same problems): Codes p0300, p0303, p1531, p0517. Engine misfire, also vehicle has a bottom end knock indicating engine bearing failure. ocv's leaking into engine harness and bulkhead harness. LF lower control arm bushing loose, RF ball joint loose. They quoted me $8000 to replace engine and fix it.....
Sorry, should read 2020 Forester
Had brakes done the day before the lights came on. Subaru said they were done incorrectly and a drum/ rotor upside down. The friend who did it wrong still has not fixed it
msb
