Decimal Cat
Hey folks,
I have a 1991 Subaru Loyale wagon (automatic, 4x4, EA82 fuel injected,
122,223 miles) and I'm having a bit of trouble with the cooling system. No,
it's not overheating, the problem is that the cooling system is working a
little too well.
Here's the story. Ever since I've owned this car it has run well and
heated well, and the temperature gauge during normal running would creep up
to about 1/4 and stay there, where it seemed happy enough. Last week, the
heater stopped giving much heat, the car was taking forever to warm up, and
so the cause was identified immediately: a bad thermostat. It was replaced
this morning, and it heats quite a bit better, plus the engine is running
slightly smoother than it ever has. . the only problem is that the fact the
heater is working notwithstanding, the temperature gauge still never rises
above 1/4. In almost any other car I've ever driven, the temp gauge crept up
to 1/2 or so and settled there.
So my question is, is this normal for the car, or is the temperature
gauge malfunctioning? The fact I'm getting heat out of the vents proves the
motor isn't running completely cold, plus as I said before it runs a bit
smoother with the new thermo in place. The car is quite driveable in this
state and runs well, but my worry is that if the gauge is right, and this is
abnormal for a Loyale, then I'm doing damage to the engine by running it too
cold. This car is my daily driver, so I really need to know if there's
something wrong with her *before* she breaks down and strands me on the way
to work.
If the gauge is malfunctioning, can someone tell me where the sender
unit for it is? If 1/4 is normal for a Loyale then I have no problems with
the car as it is now. =) Gonna have it re-painted next year.
Finally, on a completely unrelated note, does anyone know where the rear
washer filler cap for a Loyale wagon is? Or does it run off the front
resevoir and I just have a kinked hose somewhere (on the car, not me
Thanks for any advice, will also be trying the wonderful USMB when I get
a chance. Hope all you nor'easters like myself are having fun playing in the
snow. .
little too well.
to work.
snow. .
