Thank you for your input but I am looking for an actual working 7 pin that does all from the preinstalled pigtail. The preinstalled pigtail has all of that running to it including the wiring from the preinstalled pigtail at the steering column for a brake controller. Last update was from Subaru that I have to buy the whole tow package including the hitch just to get their 7 pin wiring harness.Yes, it is possible, I installed a 7 pin plug on my Forester. To do so, you get a combo 4 pin/7 pin plugin to mount near the hitch, then get a 4 pin harness to plug into the preinstalled pigtail in the cargo area. You then run a fused brake control wire from the brake controller along with a fused constant charging wire if desired.
I had the same issue when I damaged my plug on my 2020 Ascent. You can get a replacement plug from Hopkins Towing Solutions. I picked one up at O'Reilly's Auto Parts in stock but you can order one online (part 11147210). This is the original wiring plug/harness Subaru used. The existing harness plug plugs into the new 7 blade plug without having to rewire anything. You won't need the wiring harness plug that comes with it, just the 7 blade plug. I had to replace the mounting bolts as they were rusted and would not un-thread (5mm hex head x 1")Thank you for your input but I am looking for an actual working 7 pin that does all from the preinstalled pigtail. The preinstalled pigtail has all of that running to it including the wiring from the preinstalled pigtail at the steering column for a brake controller. Last update was from Subaru that I have to buy the whole tow package including the hitch just to get their 7 pin wiring harness.
