2025 Subaru Legacy Touring XT will not start
My new 2025 Subaru Legacy Touring XT will not start? The starter motor will not engage. After I leave it overnight it will start in the morning. I have had the Touring XT car for a month and this has happened twice.
The dealer can not find anything wrong it. There is no error code and its starts fine for them when they try it.
Yes the dealer told me they thought it was the steering wheel which needed to be turned slightly. This is the eight time it has failed to start since I have owned it for 1 month and it is not the steering wheel. I took the car back to the dealer and the are trying to figure out what is wrong with it.
Can they replicate it? Can you recreate it on one of the other cars on the lot?
When it wont start in Park, jiggle the stick shift while the key is turned to the start position. If it doesn't start, then with the key in the run position, shift into neutral and try to start it again. If either one of those solves the problem and the vehicle starts, then it has a defective park/neutral safety switch.
If it doesn't start, then the most likely culprit is the starter itself or the wire from the ignition switch to the starter. I once had a vehicle with these exact symptoms, the connector on the wire from the ignition switch was recessed and would sometimes not make contact. I replaced the connector and had no more problems.
aleo3
