2025 Forester hybrid fuel filling problem
When I try to fill tank, the pump stops every few seconds. Has anyone run into this problem?
Back the nozzle out just a bit and try again. Putting it in all of the way doesn't work with a lot of cars, new and old.
Tried that, but no success. Guess I'll have to take it to the dealer to check it out.
After a shutoff, what does your fuel gauge tell you? How full was the tank, before/after stopping for gas?
Dan
After shutting off severatimes, I managed to get the tank about 3/4 full.
Hmm, odd. Backing out the nozzle/different pump, didn't help. How often has this happened? Is this an ongoing problem, or just once or twice?
Yeah, let the dealer take a look, perhaps a kink in the filler hose.
Frustrating.
Dan
My '05 did it today. Repositioned a few times and got it to work.
Okay, bspill, let's take 3 giant steps backwards. How long have you had the car? Did you buy it new?
Dan
Okay, so these were your first, several attempts to refuel your vehicle?
Were they the only attempts to refuel? Or did you ever successfully, fully refuel the vehicle?
Is there any chance that the tank is full, and the gauge misleading you?
If it's a brand new vehicle, then you do want to talk to the dealer.
Dan
This happened to me this morning. Tried twice on one pump and again at another pump. Would only pump 60 cents worth of gas. Went to a different station later and it worked fine.
My 2008 Forester does the same thing. I was told that it was some type of fuel or vapor back-up. I replaced the charcoal canister. To no avail. It started suddenly about a year ago. I now have to back out fuel nozzle, and fill very slowly.
OK, this is not related to a Subaru but it might help you. I have a 2021 quantum KW 29 class C RV on a Ford E450 chassis and for the first three years I suffered with a similar problem where I would have to nurse the gasoline into the tank at a very, very low flow rate otherwise it would stop the flow of gasoline 20 or 30 times during a fill up and those fill ups took forever given the 54 gallon tank!. When I first addressed this with the Ford dealer, they said that when the RV manufacturer put the shell of the RV onto the E450 frame, they kinked the gas inlet hose and since I never went back to the RV dealer to address this, I lived with the problem for three years. Then I brought it to another Ford dealer who said that there was a mechanism in the fill line that malfunctioned that was causing the problem. They replaced the device in the fill line and now I can slam the gas in as fast as the pump will deliver it, normally 6 to 8 gallons per minute. Fill-up time is now 4x faster. Don’t know if that might be your problem.
Did you ever figure this out? I bought my 2025 in February and I am struggling with the same issue. Seems to happen when the tank is low. Dealer has not idea. I do have a video of it happening though.
did you scan for DTC, Diagnostic Trouble Codes? The EVAP system uses two solenoids, one of which is called the Vent solenoid, and the other is called the Purge solenoid. They work with the charcoal cannister to trap gasoline fumes in the charcoal cannister, and then draw those vapors into the engine where they are harmlessly burned.
This sounds to me like a vent solenoid that is stuck shut! In normal operation, the vent solenoid is OPEN, and it only closes at the moment the computer brain decides to draw the vapors into the engine via the intake manifold vacuum. The purge solenoid opens when the vent solenoid closes. Check with your scan tool for an EVAP problem.
It is a classic case of not opening up to allow the operator to pump gas into the gas tank.
We all know solenoids that turns things On and Off, but in the EVAP systrem they can work on a duty cycle that turns them On-and-off rapidly, and this is best expressed in percentages.
All that work can cause them to wear out and jam up.
msb
