2024 Crosstrek Random Beeping Noise
Hi! I have a 2024 Crosstrek with under 12,000 miles on it. This morning while driving to work it began to randomly start making a beeping noise. The noise sounds similar to when you are not wearing a seatbelt and will periodically get louder or quieter. It would beep for a couple of minutes and then stop randomly. The beeping would start back up when I make a turn, go over a speed bump, or break, etc.
There are no signals or warning on my dashboard and nothing is showing as needed for maintenance. I'm worried about what it could mean or if this is something that has happen to others with a Crosstrek because the nearest Subaru dealership is over an hour away.
Thanks so much!
I have a '22, but since yours is so new a call to the dealer is likely your best route. Make sure there is nothing on any of the seats heavy enough to prompt the seat belt warning system. It may be a sensor in the system that's off - or just bad.
Thanks so much!
No other shops closer to you?
Rilito_Supreme
