2023 Legacy Premium battery replacement?
My subbie will be 3 years old in feb...with 23k miles. Should I be changing the battery? Should I stop at auto zone and does their free testing tell me anything. I hate to just wait till it dies but hate to swap out a good battery.
I see Costco has an interstate but I must install myself..not sure if it's a big deal. Sam's club installs,I think they might use Duracell?
Do I. Need amg series 35? 600 or more cca?
Thanks!
Battery testing these days mostly sucks. You could do a basic test yourself with a quality meter. Ask if you want more info. The stores can do a load test. At three years, if it is dying...you bought sucky battery. My Bosch AGM are on 6 years+ now and going strong.
It is the OEM battery that came w/car ....no idea how long they last. My wife's 2018 Forester died after 3 years...One day it simply did not start. No idea if there is a way to tell its about to die until you simply get stranded...?
Ugh. Subaru batteries are THE WORST!
Batteries CAN fail immediately, but in general, they can be tested and you know in advance.
Short version:
After letting it sit overnight, put a DC voltmeter on it (meter must be decent quality with good batteries-low batteries provide false readings). See attached chart for rough guidance, as wet/AGM/Li are slightly different. You can see what your static voltage (#1) should be in the charts.
Start the car and take a measurement at idle (once it warms) (#2) and at RPM (3k or so will be fine) (#3). It should be at charging voltage (14V +- .7v)
If those are good, you're mostly good to go. The auto places put the battery under stress/load. This can guide you that your battery is on the way out. One of my Bosch batteries failed the load test for two years now but is till chugging along just fine in use and with the other measurements. It isn't an exact science as there are a lot of variables from one brand to another and one battery to another.
A few measurements from my now into its 7th year Bosch so that you can see the theme over time:
12.52 14.46 14.56.
12.64, 14.11, 14.18
12.77 13.97 14.07
12.76, 14.14, 14.23
I never worked with. Meter...ugh!with all the crap on the dash you would think some sort of warning might pop up suggesting it time to start looking ...are the Costco or samclub batteries ok?
Not sure. I've tried a bunch over the years and these Bosch AGM have been far better in performance and longevity.
Meters aren't hard. Maybe you have a friend with one! Maybe post your location and someone on the forum will live near you.
Where does one find a bosch series 35 battery? How much? I did see one in Costco today for $125 bucks but you must install it yourself. I have no idea how to tell if it's an AMG. It said 640 CCA, 100 reserved a and 800 CA no idea if this is good or crap or what?
$125 would be a pretty sucky battery, I would think. Try Google shopping. They're closer to $300.
Sadly, while you need to have the specs, most newer batteries die long before the usual 5 year mark. If you get free replacement...great, but that doesn't help you by the side of the road...in the dark...with monster lurking about. lol
Did you search Google? Dude...Google is your friend. Something like these.
Verify fit.
My 2019 Impreza is on it's 3rd battery; the stock battery gave out at 3.5 years, left me stranded, called AAA for a battery....BIG MISTAKE!
The AAA battery was under-sized; they put a plastic-cardboard sleeve around it to fit the holder dimensions. Piece of junk lasted only 16 months. Never, EVER buy a battery from a AAA truck! They are crap.
So, I went out and bought an AGM battery. Costs about $200+, but it has never let me down yet. I can leave the car to sit for 3 weeks and it still turns over and starts without issue. No problem starting even at -10°F.
msb
