Long story short, the gate is doing the things many others have described. Opening halfway and closing, buttons not responding, etc. A little research tells me this whole situation is in need of a recall and has been for years. None of the simple button related fixes were working so I thought it would be great if I could just convert it to a manual lift.
Picked up a couple supports and swapped them out. Had to dig up into the headliner to disconnect the driver side motorized support. Hatch then raised and lowered easily, and remained up when opened.
I was hoping this would allow the gate unlock to work, preferably by the door button or at least the key fob. But no luck. Disconnecting the support disconnected the unlock as well. Though it will still engage when closed. For the time being, I rigged a string to the manual door release, which is pretty janky and not a long term solution.
Then to make things worse, when the car is started, it beeps. And beeps and beeps. It recognizes the missing part and wants you to know about it.
So I'm wondering if anyone has been successful here in converting their liftgate to a manual. I've looked around and not found anything useful. Would love to get off the "spend a few hundred $ on a new poorly designed motor every few years" train.
