2022 Subaru Forester Spark Plugs Qs
I removed the car battery; however, the space is still too tight to disconnect electrical connectors to ignition coil (driver side). Any suggestions on how to easily accomplish this task? Any specialized tools to remove the connector. I know how the tab mechanism on the connector work but just not enough space to disconnect. Please advise for first time DIYers.
When changing the plugs on a 2018 Forester, I learned it is better to leave the coils connected to the electrical harness. The reason is there is a small gasket in the connector that can become unseated when the connector is removed from the coil. The out-of-position gasket then prevents the connector from reattaching to the coil. In my case, I could not get the gasket back into its proper position,, and ended up using a pick to remove the gasket. With the out-of-position gasket removed, I could get the the connector to fully latch back on to the coil. I put dielectric grease around the portion of coil that the connector slides over as a substitute for the missing gasket. See the first link below for more details. The second link is a video on how to replace the connectors if that becomes necessary.
https://www.subaruforester.org/thre...harness-only-goes-in-halfway-pictures.867993/
On my outback, I had to move some wire harnesses by pressing the tabs on the holders
msb
