2015 Subaru Impreza 1.6 Front ABS problems
Hi, after changing the front left wheel bearing on my Impreza, the abs light and and engine lights came on. I was told to replace the wheel speed sensor which I did but it didn't solve the problem. So I replaced the wheel bearing again but this time with a timken bearing but again still no luck. Has anyone had this issue?
Thanks
You need a different source for "advice." Is the wiring of the ABS switch good or was it (likely) damaged when you did the wheel bearing?
ResoNate
