2013 Subaru Outback, Low Beam Replacement
WTH! I don't believe that there is another way to replace the LOW beam bulb. What an engineering nightmare! Planed perhaps? Anyway, had to replace the Low Beam bulb on the drivers side. Went through the steps of removing the tire, removing most of the wheel well plastic and push rivets. Then you have to maneuver, with one hand, in a tight space to remove the protective cover for the low beam light. Such a tight spot. Anyway, most of you know the drill and I won't bore you with more of this. I broke one push rivet and found that it is very hard to find the proper part number and description as well. I believe that there was two, different sizes in removing the wheel well. Anyone, have experience with the part numbers for these pins? Don't want to approach the dealer, to pay dealer prices. Thanks.
sdes2003
