2013 Legacy Both Low/High Beams Very Dim Need Help Tracing Electrical Issue
Absolutely. I’d make the post detailed enough that experienced Subaru members **don’t start by telling you to replace the bulbs, DRL resistor, alternator, or fuses again**.
### Suggested thread title
**2013 Legacy – Both Low/High Beams Very Dim – Need Help Tracing Electrical Issue**
### Copy/paste post
> Hi everyone,
> I’m hoping someone familiar with the electrical/headlight system on the **2013 Subaru Legacy** can help me track down a persistent dim-headlight problem.
> **The basic problem:**
> Both headlights illuminate, but the usable light output at night is extremely weak. Both sides seem affected about equally. High/low beam switching works, but overall headlight performance is poor enough that driving at night is difficult.
> The car previously had some front-end damage. I replaced the **front bumper and headlight housing/assembly**, and I have been working through the lighting system trying to determine whether this is an electrical issue.
> ## Parts/work already completed
> - Replaced front bumper.
> - Replaced headlight housing/assembly.
> - Replaced **all headlight bulbs with halogen bulbs** — this is NOT an LED/HID conversion.
> - Replaced the **DRL/daytime-running-light resistor/module**.
> - Replacing the DRL resistor made **no difference**.
> - Both left and right headlights appear similarly weak.
> - Low/high beam switching does work and produces a visible change in light output/pattern.
> - AUTO versus manually turning the headlights ON does not appear to solve the problem.
> ## Battery/charging system tests
> Using a Fluke 77:
> - Engine OFF: **12.98 V**
> - Engine running: **14.29 V**
> - Engine running + manual low beams ON: **14.27 V**
> So the alternator/charging system appears healthy and voltage does not collapse when the headlights are switched on.
> I also performed a voltage-drop test directly between the **positive battery post and positive battery clamp** with the headlights operating.
> - Drop was only approximately **0.000–0.003 V**.
> There is some visible corrosion around the battery terminal, but electrically the connection appears very good under load.
> ## Headlight fuses
> I checked the four under-hood headlight fuses:
> - Both 15A low-beam fuses
> - Both 10A high-beam fuses
> All visually appear intact.
> More importantly, with the engine running and low beams ON, I measured approximately **14.2 V on BOTH test points of BOTH 15A low-beam fuses**.
> I then measured voltage drop directly across one of the low-beam fuses while the circuit was operating:
> - Approximately **0.019 V**
> So I don’t appear to have a significant voltage loss through the low-beam fuses/fuse contacts.
> ## Headlight relays
> I located the separate **H/L LO relay and H/L HI relay** in the under-hood fuse/relay box.
> The two blue relays appear identical.
> I removed one and tested it:
> - Relay coil resistance: **162.8 ohms**
> - Main switched contacts: **OL/open when relay is de-energized**, which appears normal for a normally-open relay.
> I then **swapped the high- and low-beam relays**.
> There was **no obvious improvement/change in the dim-headlight problem**, so I don’t think one individual headlight relay is the cause.
> ## Low-beam relay socket
> I also removed the low-beam relay and tested the socket.
> With car/headlights completely OFF:
> - Essentially **0 V at all four relay socket terminals**.
> With ignition ON and headlights manually commanded ON:
> - One of the large/horizontal relay terminals showed approximately **12.x V**.
> - The other terminals were essentially at 0 V relative to battery negative.
> I have **NOT jumpered any relay terminals**, because I don’t want to start bypassing Subaru’s control circuitry without knowing the exact terminal assignments.
> ## Chassis/ground testing
> Because I initially suspected a bad ground, I performed voltage-drop tests from the **actual battery negative post to chassis/body metal with the engine running and headlights operating**.
> At a front chassis point near one headlight:
> - Approximately **0.001–0.003 V**
> At a chassis point on the opposite side:
> - Approximately **0.005–0.007 V**
> Those numbers seem excellent, so I don’t appear to have a general battery-to-chassis ground problem.
> I have NOT yet been able to measure the actual switched-ground/control circuit directly at the bulb.
> ## Where I am now
> So far I appear to have:
> **~14.27 V at the battery → ~14.2 V through the low-beam fuses → unknown voltage at the actual H7 bulb.**
> That last part is what I haven’t been able to measure yet.
> Access behind the headlight assemblies on this car is extremely tight, and I believe I may need to go through the wheel-well/bumper area to get enough access to back-probe an operating low-beam connector.
> I understand that the **H7 low beam is a two-terminal, single-filament bulb**, and that the Subaru headlight circuitry uses ground-side/switched-ground control, so I don’t want to randomly add grounds or jumper terminals without understanding the factory circuit.
> ## What I’m hoping someone here might know
> Has anyone experienced this on a **2010–2014 Legacy or Outback**, where **both headlights operate but are unusually weak despite normal charging voltage**?
> In particular, I’m looking for information about:
> 1. A known **headlight harness/connector failure** on this generation.
> 2. A common **junction connector or splice** shared by the left/right headlights.
> 3. A headlight-specific ground/control connection that I have not tested.
> 4. Known melted/high-resistance **H7 connectors or pigtails**.
> 5. A known problem inside the **under-hood fuse/relay box** despite normal voltage at the headlight fuses.
> 6. Any involvement of the **Body Integrated Unit (BIU)** that could realistically cause this symptom.
> 7. Any Subaru **TSB/service information** specifically addressing poor headlight output on the 2010–2014 Legacy/Outback.
> 8. The best accessible point to perform a **loaded voltage-drop test downstream of the low-beam relay** without removing the bumper/headlight assembly.
> I’m especially interested in anyone who knows the factory wiring diagram and can identify the **specific connector numbers, junctions, grounds, or relay terminals** I should test next.
> My next planned test is to gain access to one low-beam H7 connector and measure **voltage directly across the operating bulb under load**. If I have ~13.5–14 V directly across the bulb, I’ll stop chasing the electrical system and investigate housing optics/aim. If voltage at the bulb is substantially lower than the ~14.2 V measured at the fuse box, then I’ll know I have a downstream wiring/control-side voltage drop.
> Any experience with this particular generation would be greatly appreciated. I’m trying to diagnose this methodically rather than keep throwing parts at it.
I think that's the right level of detail for a Subaru-specific forum. The last paragraph is especially important because it tells the experienced electrical guys **exactly where the diagnosis currently stands** and invites them to point you toward a specific connector or wiring-diagram location rather than restarting troubleshooting from square one.
Were your headlights noticeably brighter before? I have a 2010 legacy so same generation and I ended up switching to LED bulbs for the low beam as the stock bulbs were relatively dim
Also did you get new headlight housings or used ones? If they're used it could be that they're just hazy or yellowing and need a cleaning.
I appreciate the details put into the AI prompt but for future reference you should delete the paragraphs that arnt apart of the post, some people see an AI written prompt and immediately stop reading
Voltage is like the "pressure" of the system. I would suggest you measure the Amps flowing thru the circuit instead.
You obviously have an amperage problem, not a voltage problem. Also, do you have a light meter? Photographers use to always have a good light meter before taking a photograph.
Another idea is that your eyes have developed cataracts, and this is most notable at night, so go see an eye doctor to have your eyes checked.
Shame on you for not cleaning your battery terminals first, before wasting all your time checking voltages.
There is a special tool that can save your computer programming before you disconnect the battery. Also, remember that a good mechanic always disconnects the Ground cable first.
I am not a big fan of AI, but it can be helpful in some cases.
Thanks for the responses. I've been trying to isolate this systematically rather than continue replacing parts.
Regarding the battery corrosion, I measured voltage drop directly between the positive battery post and clamp with the headlights operating. It was only 0.000–0.003 V. Charging voltage is 14.27 V with the headlights on, and both low-beam fuses measure approximately 14.2 V.
I've also checked the chassis grounds, which showed only 0.001–0.007 V of voltage drop.
I agree that current measurements could be useful, but I haven't yet measured voltage directly across an operating H7 bulb. That remains my next electrical test.
I'm also interested in the possibility that these Legacy models simply have poor factory low-beam performance, or that the replacement headlight assemblies have inferior optics.
I'd be interested to hear whether other 2010–2014 Legacy owners have experienced unusually weak low beams with otherwise normal electrical measurements.
As for the amperage, which is the actual flow of current, you still have no idea, right?
I got in trouble when I first joined because a forum reader could not find the 9 Volt Memory Minder that plugs into your ashtray was not actually callede a Memory Minder, and instead of $15, it was $79.95!
So, here is another idea: just use jumper cables to a spare 12 volt car battery before you disconnect and clean the terminals.
The idea of the light meter is to actually measure the footcandles, or brightness of the headlights. Until you make scientific measurements, it is all guess work. BTW, I despise modern headlights that are too blue. Give me the old soft yellow headlights that were standard for so many years.
In my case the electrical system worked fine and as it was supposed to, the stock low beam bulbs just really were not that bright
A cheap set of LED low beams was like $30 online and was a straight forward swap in my case. Truthfully if everything seems to be working fine, your high beams and everything work like they should and nothing is flickering then I think you might be chasing an electrical issue that doesnt really exist and plugging in a cheap set just to see how it goes is a pretty straight forward and easy test, if they still seem dim after that then that would easily confirm a potential electrical fault but it sounds like everything is working the bulbs are just dimmer than you would like?
If you can upload a picture showing the lowbeams on at night so we can get an idea of how bright they are that may help others that can compare to their own cars.
When you get access to the connector for the bulbs, I would recommend measuring the voltage from the ground terminal on the bulb to battery negative. If it is less than 0.01V, then that should rule out a ground problem.
I have a 2014 Legacy 160k miles, never wrecked, owned since new and my head lights are dim as well. They got dimmer with age. They are so bad that my head lights cast a shadow when there is another vehicle behind me.
I've had this happen before on two other vehicles, I keep my vehicles for a long time, and in both cases it was the silver reflective coating at the back of the assembly that projects the light forward got less shiny and got so thin the allowed light to leak into the engine compartment. Had to replace the housings.
I know you said yours were replaced, but if a body shop replaced them, it is likely that they used used lights. It is a common practice for a body shop to buy a complete front cap, bumpers, fenders, hood, grill, radiator frame and headlights, and put that on a vehicle with front end damage.
msb
