2013 Impreza Headlamp troubles!
Good morning everyone!
My friend is having headlight trouble. I've tested the bulbs and ATC fuses. They are good and have continuity. But the Driver-side bulbs and high/Low beams work. The Passenger side does not! The wiring into the connectors looks sound. Nothing is frayed and the wireloom is in fine condition. The contacts are not corroded. There are two relays marked "H/L Low" and "H/L High" Is it possible these individually supply power to or split power to one side of the circuit? It seems weird to design such a simple circuit to split loads that way. Removing the relay from its mounting seems to require a specific tool or special plier to pull it out. Any suggestions?
Runaway Outback
