First the hill assist comes on after 5 minutes if I hit the brakes the light goes off if not then after awhile the abs and the track coms on not to be shut off and the brake lights stay on. If in garage I stomp on the brakes after I shut off the car.That sometimes work. Will try the jiggle method you suggest.my guess is it is in the back up light switch in the shifter mech. next time it is on go jiggle the shifter lever and see if its goes off. or while they are off go jiggle and see if they come on. Sounds like when you first stop all is good then after awhile the shifter moves slightly and turns on the lights
