2012 Subaru Impreza Retains $17,495 Base Price
kaboom said:
Oh Subaru. My car goes off-lease near the end of October and the new models are out in November. What to do now?
http://gadgets.autoblog.com/2011/08/19/redesigned-2012-subaru-impreza-retains- 17-495-starting-price/
A more in-depth article on the new Impreza:
http://www.autoblog.com/2011/04/20/2012-subaru-impreza/
Tje thing that bugs me about the new Impreza is that while it gets better gas mileage than the previous Impreza, it requires the use of synthetic oil. I wonder if anyone has worked the numbers to see if the increased cost of every oil change cancels the savings from the better gas mileage?
You should be using synthetic oil anyway. Go to Walmart and get 5 quarts for under $20. Get a Supertech filter do it yourself and youre still cheaper than a garage plus you know the job was done right.
Why should synthetic oil be used? Is this what is specified in the manual?
http://gadgets.autoblog.com/2011/08/19/redesigned-2012-subaru-impreza...
kaboomie
Is that the new 2.5l with the timing chain? maybe that has something to do with it?
Also, did the oil change interval lengthen in the manual with the synth-oil requirement? That might hel pmitigate some of the xtra cost.
The only qualification to be a car designer today is to be a follower and have no style. The Outback has been ruined and now the impreza has the same front and side profile as every nissan, toyota etc.
First things first- if you lease a car use the cheap oil. If you keep a car for a long while synthetic has several advantages- 1. handles higher heat 2. flows in colder temps 3. better lubrication 4, higher mpgs. I havent seen the new manual and likely wont as my next car won't be a Subaru based on designs alone. It Took how long for them lto lose the #%@^#@ timing belt!
Hi ya, Kaboomie! What are you looking at for a replacement? Come up with anything yet?
**Well, I was shootin' for a 2012 Impreza, guess not. Subaru has a lead over the others in that 1. I like them, 2. I have $500 in Subaru bucks to go toward a new purchase or lease and 3. If I lease, they'll also pay for the first month. A few weeks back, Subaru sent me a letter saying that there was a strong possibility that they wouldn't have some of the models I might be looking for so I can also extend my lease and they'll give me some goodies in case I have to do that.
Frankly, I don't want the vehicle anymore, it's too long in the tooth for a lease. I'm sick of this fucking shitty interior. It undermines the fact that the car itself has been fantastic. I've spent over 3 years making sure that the car stayed minty fresh and, even though it looks freakin' great for +3, it's going to go downhill...starting with my Mom backing into it yesterday morning. Then, she left and didn't say a word to me. When I went to her work place to say: Uh, you hit my car. She replied cheerily, Yea, so? Clearly she does not understand the term: Lease.
I'm thinking of buying so she can run into my car with impunity.
kaboomie
**But But But, the Impreza has "POWERFUL WHEEL ARCHES!"
If the Autoblog in-depth story on the Impreza is true, it really has been improved. Aside from a long list of things, I liked this:
"The driving experience should be improved because of the car's stiffer body and wider track, expanded by a half-an-inch in front and
0.7-inch in back, and refinements like the stronger components, a new stiffening crossmember up front and pillow-ball bushings in the double-wishbone rear suspension from the STI. Spend on the upper trims and Subaru adds different springs in the front dampers and a rear stabilizer bar."
kaboomie
You should want your mother to have peace of mind!
On Sat, 20 Aug 2011 09:20:35 -0700 (PDT), Big Jim
Same price, much reduced torque and horsepower
from way smaller engine? Sounds like they're
after fools.
Basia
after fools.
**Well, I guess I won't buy one now because I would be a fool. Better interior, sportier ride, better gas mileage be damned. I needed that 170hp to get me the 1.5 miles to work and back gosh darn it!
I guess Subaru is trying to tap into the market
for underpowered cars. Underpowered cars with
sportier rides, better interiors, etc.
It is a big competitive market. It remains to
be seen how deep of a market for an AWD vehicle.
People in mountainous regions- traditional Subaru
bastions, will likely not buy this new Impreza.
So it is essentially a bet on flat-landers.
With plenty of incentives it can work, probably.
Basia
Why? Some gullible folk won't pay extra for wrx
and will slug up the hill in a normally breathing impreza.
Basically you don't want to slug you'd pay for wrx you
want to be a fuel sipper you stay low with this basic model. Mind you, the torque peak arrives earlier on 2.0 than on the outgoing
2.5
and I hated the old 2.5 slug with my whole heart. Soooo slow to spin up.
I like how the new car looks even compared to 2005 impreza.
Heck, Basia, you haven't even driven the car.
323 (Protege) looked even blander on paper but it was hoot to drive. Celica also is not much at 122 but with a single lightweight pilot it was probably a blast in the twisties.
With the 2.3 gallon reduction in gas tank capacity FHI needed that improvement in the mileage. I wonder if wrx and sti would share the new puny gas tank. They probably will and that'd be a pity. I hear the sound of subaru plonking the spare tire next to fix the gas tank issue in the next installment :-[
There are three kinds of lies: lies, gross lies and car specs.
Nothing in between- that's the problem.
2.5
It may be a bit more "free-revving" but longer stroke
engines are generally not of such nature, that's
what they did to the 2.0L - made it a longer stroker.
I'm sceptical.
They should offer a choice of engines, like a 2.0,
and a 2.5, but the CVT is probably a weak one
(supposedly smaller version of the the Legacy's)
so can't handle more torque.
Bad. I don't like what they are doing to the Impreza,
turning what just a few years ago was a relatively fun
to drive car a fun car into some 'commuter.'
Why not a Civic, or Corolla then, or the upcoming
Prius C (City) Hatch, it looks so sexy, and promises
to be the cheapest hybrid.
Basia
**150hp is underpowered? I'm constantly reading how people think the engine in my Impreza now is a slug, do you think they are talking about the automatic? I have a 5 speed and don't think it's even remotely sluggish. I will say that I understand you're peeved because Subaru is going all middle-America milquetoast with their vehicles. Trying to broaden its appeal perhaps?I don't disagree. I loved my 2005 Impreza wagon and I wish I still had it. It was fun and also had fewer HP than my current Impreza which I like a skosh less (crappy interior design-wise and quality-wise).
**I live in a hilly region that gets tons of snow. I'm surrounded by Subarus now and will most likely continue to be surrounded by even the new 2012s. In my area, however, I think that Hyundai is giving them a run for their money and I say: good. Hopefully, this leads to improvement.
**I don't know about Subaru's rep outside of New England. I know that here in NE, they are gold.
We'll have to wait and see.
It may be adequate with a manual transmission
on flat or moderatly hilly terrain.
In the mountains of Colorado, Sierra Nevada,
or Cascades, where many if not most US Subarus
find their home, it will not be optimal.
I am absolutely sure it'll have to be revved
a lot. With AWD 2012 Impreza will be a fairly
heavy 3000lb vehicle, while top power will
be coming at a high 6200 rpms.
A slightly larger, say 2.2L variant of the
engine could have been much better. Maybe
they'll offer a bigger engine later on, if
the CVT is not an obstacle (?).
Subaru probably has direct injection in mind
for the future, and for this market segment,
and that is why they settled for a relatively
small displacement engine.
Direct injection is not a perfect technology,
though. Nasty carbon deposits are known to form,
diminishing performance, and requiring periodic
cleaning of intake valves. Larger oil capacities
are also needed as unburnt gasoline is known to
dilute engine oil in these engines. Synthetic oil
may be needed(?).
Hmmm, maybe I am just getting old, but I really
don't like what they are doing to the Impreza.
Basia
I'm sceptical.
because priuses always handled like crap and they probably always will
engine is only part of the fun
i don't like the outgoing impreza handling at all
if you don't like the base model there is always wrx to move up to and the whole lineup is mirrored by mitsubishi now if you want to trade up some perceived reliability of impreza for a better tuned chassis of a lancer (less understeer, better handling, etc) even the pig that it is in the 10th installment
after fools.
Oooops, my apologies to Canadians.
In Canada the new 2012 Impreza will be sold at lower
prices than the outgoing model, ...I guess for a reason.
MISSISSAUGA, ON, Aug. 22, 2011 /CNW/ - Subaru Canada, Inc. (SCI) is pleased to announce pricing for the all-new 2012 Impreza lineup, which goes on sale in October. Consumers may not be surprised that the redesigned fourth-generation Impreza offers significant enhancements over the previous model... . What might be surprising is the fact that Subaru is offering the new Impreza at prices that are lower than the previous model—at every single trim level.
http://www.newswire.ca/en/releases/archive/August2011/22/c5387.html
JoeCho
