- Joined
- Apr 28, 2025
- Messages
- 15
- Reaction score
- 4
UHG!! Where to begin.
Chasing an overheat issue with this car. 2011 Legacy 2.5 SOHC non turbo engine. Latest is it overheated almost back to home on a test drive and had no heat from the HVAC system despite running HOT and pushing fluid out the overflow. It really seems like it has no coolant flow in the system but I could be wrong on that.
Been having issues with overheating for a bit now. Replaced hoses and t-stat (NON OEM). Replaced radiator as well. All new coolant. New temp sensor as well. Used the head gasket coolant test kit and they appear to be in tact at 153,000 miles.
Fans are coming on but only on low speed. Sitting in the garage I had my Foxwell plugged in to watch to the temps and once it comes up to temp (200ish F) then the fans kick in and do their cooling thing.
Todays plan of attack unless advised differently will be to drop the coolant again and pull the t-stat and test it with hot water. If it is stuck then I will get an OEM unit. Plan to pull the water pump as well and inspect the impeller.
Honestly I am at the limits of what I can think of with this car. Open to suggestions on what to check / test / replace.
Thanks in advance.
Thanks in advance.
