2010 headlights constantly needing replacement
My 2010 Outback’s headlights are constantly going out. It doesn’t help that it is almost impossible to access the fixture. Driving me crazy. Anyone else with this issue?
Dont use silverstar ultras, they never last. When you replace the bulbs, dont touch the bulb itself. Wear a glove or hold it with a paper towel. The oils on you skin make them overheat and blow prematurely. Its also possible that you have a wiring issue that may be causing them to burn out.
Tinger
