2010 2.0D: blown fuses to the radiator fan
Bought the car a couple of weeks ago with an empty coolant overflow tank and low level in the radiator. Currently failsearching.
In the engine fuse box both fuse 31 extra fan and 32 main fan are blown. I'm looking for advice as to where to search for the reason that the fuses are blown. If I don't find it I'm assuming the new fuses will blow again whenever the coolant temperature gets high enough to activate the fans (at 89 degrees celsius I'm told).
Fuses are cheap. Have you tried any? Are they 12V? If so...just try to run one at a time with a jumper.
Donna P
