2008 Subaru Impreza WRX Clutch Issue
Hi guys, disregard my last post if you saw it. Here’s the issue with my 2008 Subaru WRX:
The pedal SOMETIMES get stuck half way up. The clutch will fully engage and disengage but the pedal doesn’t always fully return back. I topped my fluid off - because it was low - and looked in the reservoir. This is what the reservoir fluid looked like. I can’t tell if that’s material from the master cylinder down in there or if thats on the outside of the master cylinder reservoir. I have no visible leaks or anything like that for the master either. Could it be a simple bleeding needing to be done?
I did notice that when pushing the clutch in by hand, the mechanism that pushes the clutch - that is attached to the master cylinder fork going to the clutch pedal - seems to get stuck. Could it possibly just need some greasing or something?
Updated the post with video! Drove completely normal on my 30 minute drive home from work but issue was happening first thing this morning driving to work. So its weird when it does or does not happen. Any ideas?
Clutch pedal getting stuck
Clutch pedal travel
DaveZ
